![]() Quote:
Jeff |
![]() Quote:
BEST OPTION! |
If you can weld, maybe just screw like two nuts onto the rod then screw your clevis back on then weld the nuts to the clevis. I guess that's what I would end up doing, or drilling the new holes in the lift links. Just a thought.
thnx gonna try a longer lift rod first.
By chance, are those vertical lift straps for a super? They look too long and I don't feel extending the lift rod is the best solution. If this blower is still on the ground with the pivot assembly at the angle it's at, then the angles are going to be real bad if you extend the lift rod enough to pick up the blower.
1450 w/ 44gt deck, 1572 w/ 50C deck, 450 snowblower. |
Yea I agree you might run out of travel. The supers arms are 12.91" long and standards are 10.2 long if that helps.
I was just out and looked at my 451 basically same thing. on mine the lift arms have 3 holes in the bottom and mine is in the middle hole. I would think it would be a better option to punch a set of 1/2" holes in the lift arms. sbauerz28 is correct if you extend the lift arm something could possibly bend or break.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
![]() Quote:
I added 3" to my lift rod and it lifts it 4-5" off the ground easily now. In the spring , I plan on making new lift straps . thanks for all the help we got that 4 letter word in the forcast here for friday. |
![]() Quote:
![]() Good to hear it's ready for that four letter word Jeff |
