https://www.shcsupply.com/products/5...%7C147067.html
Anyone know anything about this oil from lube king? Supposed to be a hytran substitute. Or is this like the 303 hyd oil from orscehlens?
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Pretty much what I use. No issues at all
It's close but not the real thing.
Oh no not the dreaded Hy-Tran debate.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
The only thing I'll say is,
do be aware some oil has a higher viscosity and will give you problems in cold temps, like slow or no starting and pump cavitation till really warm. 303 from tractor supply did not like to flow well @ colder temps for me. |
Whatever fluid you choose to use be sure it says non foaming, if the fluid foams when hot it will put air in the system and cause the pump to over heat. I run hydraulic/trans fluid from Brad Penn, its what we use in the Ford select o speeds.
I stand firmly in the "there is no substitute" category. I figure the price is just part of the cost of having these toys.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
I always love reading through these hytran "debate" threads; always get a kick out of em
-Ryan
I've gotten to the point that I don't even comment anymore. Read the manual.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
