Old 12-24-2015, 11:24 AM
southeastern southeastern is offline
Default 3- Point hitch question
Hello all, I have a GT 3100 and considering installing a 3-point hitch, I know there is a lift cylinder on the tractor now, dose the 3-point utilize a lift cylinder of its own, the used hitch that I'm looking at doesn't have one with it, Thank you for your help.
Old 12-24-2015, 11:27 AM
olds45512 olds45512 is online now
It should attach to the existing lift cylinder.
Old 12-24-2015, 12:35 PM
You will need the lift cylinder on the 3k machines. If you found a hitch for less than $500, buy it! They are NLA and nobody at this time makes an aftermarket. Here is what the model 365 hitch looks like.
This is for the older 3k machines with the dual disc brakes. You will need the model 207 hitch. I think you can make the 365 work but will need to fab up a few parts.
Old 12-24-2015, 12:39 PM
Attachment 70687
i guess i stand corrected, i just assumed it was like all the other 3 point setups.
Old 12-24-2015, 02:37 PM
So the existing cylinder lift works the deck and the 3- point hitch? What is for sale is almost all of oaks picture he doesn't have the cylinder or the bracket that the hyd. cylinder sits on behind the rear plate, however I think I purchased one of those cylinder's and the bracket is available for about $90.00 I can get what he has for $300.00 is this a decent price?
Old 12-24-2015, 03:12 PM
No. You need a second cylinder for the 3pt.
Old 12-24-2015, 03:17 PM
Thanks J-MECH, what you mean is the original cylinder lift is dedicated to the mower deck, and the second cylinder lift is dedicated to the 3-point?
Old 12-24-2015, 03:32 PM
Yes.......
Old 12-24-2015, 04:16 PM
gt383mag's Avatar
gt383mag gt383mag is offline
yup you add another valve and handle that sticks out of your fender it work ind. from the deck lift
Old 12-24-2015, 04:33 PM
Thanks for all the help sorry it took so long to reply but my 9 year old son and I took the gt out in back and took the top off the lawn... in Florida now its about 82 out side and I'm still wearing shorts, and the lawn had some high spots in it so we decided to make it level. Thanks again.
