Old 12-31-2015, 08:35 PM
1811woody's Avatar
Default Snow blade lift rob bracket abortion
I've never paid any attention because it has worked for 8 years or so. Recently when I was installing my snow blade on the 1811 I paid closer attention to the lift bracket and noticed it didn't look quit right. It appears the lift rod is shorter then its supposed to be so the P.O. hand to do a little rigging to get it to work. I guess I'll add this to the cub todo list. The picture doesn't show real well but if you look theres two different style brackets bolted on top of each other. One is a bracket with a slot which probably allows the plow to float. The other is the bracket that mounts on the plow it self.
Old 12-31-2015, 08:42 PM
I turned the picture. It's a WF front blade bracket.
Old 12-31-2015, 08:57 PM
Terry C's Avatar
Terry C Terry C is offline
You didn't notice this for 8yrs?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-31-2015, 09:07 PM
1811woody's Avatar
Thanks Jeff for rotating the pic I'm having a tough enough time just getting pictures to load heres another pic
Old 12-31-2015, 09:08 PM
1811woody's Avatar
I know good thing it wasn't a snake. Just goes to show your to old to learn.
Old 12-31-2015, 09:10 PM
bocephus1991's Avatar
Isn't that the bracket for a power angle bolted on the wrong place?
Brian
Old 12-31-2015, 09:14 PM
Old 12-31-2015, 09:15 PM
1811woody's Avatar
That's a good question, I'm going to look at partstree and see what I can find out.
Old 12-31-2015, 09:16 PM
1811woody's Avatar
You must be magic thanks again Jeff
Old 12-31-2015, 09:19 PM
Not quite magic. I saved it to the computer and then downloaded it to my photobucket account. I rotated it and saved the correct orientation picture.
