Old 01-03-2016, 05:34 PM
john hall's Avatar
100 was on support duty for some chainsaw work in dad's yard. Yes that is a school bus seat, 8hp motor, oversize rears, and driveshaft out of Lord only knows what. Hey, this things been on work detail for the last 20 years!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-03-2016, 06:19 PM
Mountain Heritage's Avatar
Originally Posted by john hall View Post
The title of the thread is "What did you do with your Cub Today" (nothing about Cadets), therefore I say you are fine with that post! What in the world do you pull to need weights on the front, especially with turf tires?
Originally Posted by ccguy View Post
Renewable Energy detail. 29 degrees and dropping...
These are SWEET look'n Cubs!!! Nice guys!
I have been working at my cab on the 982 that I have modified. Didn't like the slanted front on the Sims cabs - so its now vertical like they should be in my opinion.
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 01-04-2016, 11:18 AM
Nice 100, John!
The 982 cab is looking good, Mike!
Old 01-13-2016, 12:11 PM
Cannon51's Avatar
Cannon51 Cannon51 is offline
While I had the fender pan off the 1641 to replace the fuel lines and fix the deck stop I decided to do something to the rusty pitted footrest. I have a small sandblaster that I went over them with the sprayed the with Rusty Metal Primer. I found some Rustoleum Marigold That looked close so I painted the bottom and sides with it. After it dried I taped off the footrest area and sprayed two coats of Rustoleum Truck Bed Coating on it. After the last coat I removed the tape and the liner had wicked back under the tape and it looked like crap. I just decided to spray the whole top side with the bed coating. It's hanging in the laundry/mud room drying now. I didn't actually do all this today. Painting in the winter without a heated shop is a PITA. I bring the part and paint in the house, let it get warm, take it to the garage and paint it then bring it back in to dry. The next step is to hunker down for the complaints about the paint smell. Picture of the footrest before the coating shows the pitted top. Picture of them hanging from the cabinets in the laundry room drying. I probably won't put them on till tomorrow.
Cannon
Old 01-13-2016, 01:16 PM
MrSam
Guest
Posts: n/a
Had to troubleshoot my non-charging issue with my 122. Ended up re-wiring most of the tractor while I had it apart.
Yes, all the wires are the same color, which isn't perfectly ideal, but I had the wiring on hand already so stuck to this as a free upgrade.
Jury is still out on if my charging issue is fixed... not been able to go back out to check on it since re-wiring it. Maybe tonight... My luck, it'll be the voltage regulator.
Old 01-13-2016, 03:27 PM
Cannon51's Avatar
Cannon
I'm going to have to give myself an unsatisfactory grade on this project. After about 2 hours of drying the coating had cracked and was lifting up. I took a putty knife and pealed it back off. It was stuck better over the primer bu came off easily over the yellow paint. All the products are Rust Oleum so I think it must be something I did. The paint was on a full day before I sprayed the coating, who knows. Think I'll wait for a warm day to try again. Or I may abandon the Truck Bed Coating all together. Picture after scraping it all off.
Cannon
Old 01-13-2016, 04:33 PM
gt383mag's Avatar
gt383mag gt383mag is offline
is it just me or does that top pic look like the tractor is bending around corner.... like it was stretched for widescreen lol
Old 01-13-2016, 06:19 PM
Terry C's Avatar
Terry C Terry C is offline
It does like fish eye lens or something.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-13-2016, 09:05 PM
MrSam
Guest
Posts: n/a
Pretty close... Used my iPhone's panorama feature to get the photo while sitting about 1' away from the tractor.
Old 01-13-2016, 09:28 PM
thats the nascar edition, only mows left.
