Old 01-06-2016, 09:30 AM
Default Wheel weight bolts
I figured before I start messing around measuring I'd just ask if someone happens to know how long the bolts should be to put ih weights on my 1050? The tires are 10.50 wide so there on the wider rims.
Old 01-06-2016, 10:32 AM
5 1/2" long IH bolts
Up to 534 and counting...
Old 01-06-2016, 11:11 AM
Thanks Lew, now I can stop on my way home and get some.
Old 01-06-2016, 11:38 AM
Terry C's Avatar
Terry C Terry C is offline
Carriage bolts but I'm sure you already knew that
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-06-2016, 01:07 PM
Really? That must be why the hole in the rim is square.
Old 01-06-2016, 04:41 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Do I need to break your nuts and ask if you know the diameter of the carriage bolts?
Plow blade
#2 Cart
QA36 snowthower
Old 01-06-2016, 04:58 PM
Actually I left work without checking, got any idea?
Old 01-06-2016, 05:08 PM
Terry C's Avatar
Terry
3225
Old 01-06-2016, 05:20 PM
I see the IH ones are 7/16
Old 01-06-2016, 05:27 PM
Terry C's Avatar
I would go with what Lew said cause my bolts came with the weights and had nuts on them already. I used a 3/4 socket is what I based my answer on
Terry
3225
