Old 01-06-2016, 07:42 PM
I've got regular grade 5 bolts on mine. Sorta difficult to do with two wrenches, but I can get one back there and tighten em up.
Old 01-06-2016, 08:20 PM
Just an FYI, some people put weights on the backside of the rim, some are on the front and some are on both. Some run multiple sets of weights on, as well. Therefore, bolt length may vary. You said it was going on a 1050, so I do not know if they will fit on the backside with the breaks.....I have never done that on those before.
Old 01-06-2016, 08:31 PM
1/2.
I see the IH ones are 7/16
I would go with what Lew said cause my bolts came with the weights and had nuts on them already. I used a 3/4 socket is what I based my answer on
I used 1/2" carriage bolts for my Gilson wheel weights.
"Heavy" 7/16-14 nuts and regular 1/2-13 nuts are both 3/4" hex
Old 01-06-2016, 08:36 PM
i will be putting them on the outside only, i figured i have a couple sets sitting here i might as well use them.
