Old 01-10-2016, 09:33 AM
Default 54" Push Blade
I recently order a new Cutting Edge for my 54" Spring Trip Blade. I ordered it from Extreme Motor Works [CC-27-012] . I ordered the optional extra thick edge [.250"]. When I got the edge, I noticed it was just a flat piece of steel, .250" thick, 54" long, and with 9 mounting holes cut in it. What surprised me was, I would have thought there would have been a "beveled edge" at the bottom. See attachment, I got Style A and thought it would have been Style B.
Am I wrong on my assumption...???
Old 01-10-2016, 09:47 AM
jimbob200521's Avatar
I've never seen a cutting edge on a Cub blade with a beveled edge so I'd say they did just fine.
-Ryan
Old 01-10-2016, 09:48 AM
cubs-n-bxrs's Avatar
One would assume it would be a beveled edge. Although I don't think it would take very long for a bevel to be worked in. Run it up and down the neighbors driveway with no skids on a few times and there is your beveled edge. J/K
Old 01-10-2016, 09:52 AM
gt383mag's Avatar
gt383mag gt383mag is offline
i thought he had what looked like scaled down version of real cutting edge. just went and looked at site and dont look like its there any more
Old 01-10-2016, 10:12 AM
biglefty's Avatar
biglefty biglefty is offline
I would think if the blade was beveled it would wear much faster. So at least both sides should be beveled so you could flip it around to get much more life out of it.
Old 01-10-2016, 10:15 AM
PGHsteelworker's Avatar
PGHsteelworker PGHsteelworker is offline
The 54" haban blades came with a piece of 1/4 X 3" flat bar with no bevel.
Old 01-10-2016, 11:54 AM
I don't think you'll have a problem with it. After I used up the factory edge on this plow I put a 3/8" X 3" piece of bar stock on it.
Old 01-10-2016, 12:30 PM
The square cut will wear in. They were square to begin with. I have a never been installed 6 way blade for a round fender 110 JD. It's not beveled.
Old 01-10-2016, 09:00 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
6 way blade for a 110?? Love to see that 1!
1- 1200 in pieces
1- 1864 in pieces
Old 01-11-2016, 06:03 AM
Thanks for all the replies. I'll put the new cutting edge on today.
