Old 01-22-2016, 10:21 AM
V30crewcab V30crewcab is offline
Default Axle and differential gaskets?
I would like to do some maintenance on my 1782 and 1862, and I'm looking for a good place to order the axle tube gaskets and the rear diff gaskets. will they be the same on both machines, or are the axle tubes different on a super? Not even sure where to find cub parts close to me, so figured I'd just order them from a website. thanks.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 01-22-2016, 10:39 AM
CubDieselFan's Avatar
Not sure about the parts you need, but I would try the sponsors first.
Old 01-22-2016, 10:57 AM
This is a list of all the seals and gaskets I used for a 2182.
Hydro Pump seals
SU-9008000-6701 seal 2
SU-9008000-7505 seal 1
SU-9008000-6201 seal 1
SU-3102875 gasket 1
SU-9004100-0360 o-ring 1
_______________________________
Transaxle seals and gaskets
921-3004 gasket 1 cork gasket
721-3014 gasket 2 carrier gaskets
921-3020A seal 2 axle seals
726-0216 plug 1 expansion plug
921-3015 gasket 1 rear cover
Those in red should be what you will need.
This is where I bought them from.
http://www.greatoutdoorpowersports.com/
Old 01-22-2016, 11:24 AM
I have used these ppl before and found they had good prices, and was treated well.
https://www.m-and-d.com.
You can just plug in the numbers to compare prices.
I am not affiliated with them in anyway.
Old 01-22-2016, 11:50 AM
ok thanks, I'll see about getting some ordered.
72 scout
IH 404 tractor
Old 01-22-2016, 02:33 PM
john hall's Avatar
Got a local dealer, Cadet probably has a dealer locator on their site.
I order my stuff from somewhere towards the mid-west. For me, ordering parts from way off somewhere is easier than buying local when local is 1/2 hr away and doesn't stock what you need. I try to look up my parts ahead of time and have the supplier verify I chose the correct ones.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-22-2016, 07:54 PM
RR1862CC's Avatar
RR1862CC RR1862CC is offline
I ordered mine from Athens Lawn and Garden which is the CC dealer north of you off exit 49. There is a dealer in Cleveland TN but I do not know there name. Thing about ordering stuff for older machines is they usually do not stock the older parts and it is just as fast to order them yourself online.
Allis Chalmers 416
Massey Ferguson MF-8
Brinly 10"plow
Old 01-23-2016, 06:13 PM
Yeah I went ahead and ordered a bunch of stuff. now to find time to work on 3 different machines!
72 scout
IH 404 tractor
Old 01-29-2016, 09:46 PM
Well I got a nice big box of parts yesterday, but it'll be next weekend before I can use any of them. oh well. at least I have them now! got parts to fix 3 of my cubs, so i'll be busy for awhile.
72 scout
IH 404 tractor
