Old 01-23-2016, 12:52 PM
seanmmcc seanmmcc is offline
Default Shear bolts on snowblower fan keep snapping
i have a cub cadet 3185 with a Bercomac two stage snowblower. Ran it last night in about 6" and it did great. Still runs well today with 2 feet on the ground but I keep snapping shear bolts and I am worried I am going to run out.
How tight should these be when replacing? Maybe that is my problem I have been leaving a little play in them should there be? It has a nylon lock nut.
I am letting the snow slowly feed in there isnt any rhyme or reason to when they break it seems like it is nearly every 15min.
thanks for your input.
Sean
Old 01-23-2016, 01:06 PM
john hall's Avatar
Never used a snow blower but I imagine the shear bolt in it is the same as a hay baler or bushog. We always just tighten them reasonably tight, nothing extra. The bolt should sit still, not hold anything together. Do you have the correct size bolt? Too small of a bolt will allow for slop which can cause failure. You are shearing the bolt and not losing the nut, correct? I wouldn't get desperate and use a heavier grade bolt, then you are going to demolish something. As long as the bolt holes are not beat out, I've never seen bolts shear unless you overloaded the machine/hit something. Is everything turning freely?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-23-2016, 01:14 PM
thanks for the quick reply. The snowblower is new to me but basically unused. So I dont think it is rounded out.
I have been leaving a little play in the bolt. I will get it snug this go round.
They are labeled with the matching part number. and appear to be the same as the other bag i got that came with the blower and were also labeled with a matching part number.
I am left with the bolt head and about a 1/4 inch of bolt shaft when they break. the nylon lock nut disappears in to the snow.
thanks again.
Sean
Old 01-23-2016, 01:20 PM
bocephus1991's Avatar
Having dealt with shear bolts on farm equipment tighten them up. Don't leave play in them. Don't go crazy tighting them but good and snug. I'd say lesviplay in them is why you keep shearing them.
Brian
Old 01-23-2016, 01:31 PM
john hall's Avatar
I'm kind of thinking he's overtightening them and stretching the bolt. Wonder if he needs a flat washer under the head and nut so as not to cause a stress point?
2072 w/60" Haban
Old 01-23-2016, 01:54 PM
gt383mag's Avatar
gt383mag gt383mag is offline
my 450 kept busting them in even light snow i put 5/16 inch grade 2 bolts in them and they seem to be holding up ok. and they do shear when you hit a ice chunk or something so they dont seem to be too hard
Old 01-23-2016, 03:02 PM
I have gone through 3 more since my first post. Having them fighter seems to help but still breaking.
Old 01-23-2016, 03:14 PM
Are you running this thing on the ground? Is something binding up? No way it should be eating bolts like you are. How about some pics of the blower so we can see the inside of it.
Old 01-23-2016, 03:17 PM
I'll check the height against manufacturers specs one sec
Old 01-23-2016, 03:27 PM
Just to be sure are you breaking the bolts in the auger or the fan? From what I can see on the Cub parts site the fan is supposed to have a spirol pin in it not a shear bolt.
