Old 01-23-2016, 04:04 PM
kpo88 kpo88 is offline
Default 3184 hydraulics work, but tractor won't move
I was plowing snow with my 3184 today, I started to notice a clunk going from forward to reverse, then something snapped, all the hydraulics are working as they should, I was able to push the tractor back into the garage so nothing is locked up, I jacked up the rear and the wheels spin like they should so I don't think it's in the diff. Looking some help where to start looking for the problem, thanks
Old 01-23-2016, 04:14 PM
PeterJ PeterJ is offline
Just a guess: Roll pin sheared. They don't always come out.
PeterJ
1863 48" deck, 3pt
1864 x 2, 54" deck, power bagger, 48” deck
1811 44" deck 1210 44"deck
IH trip plow
QA42-A, 451 x 2, 551
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
Old 01-23-2016, 04:47 PM
3184's don't have spirol pins. Sorry to be the bearer of bad news but If I had to bet, I'm guessing that you have broken bolts in the diff where the bull gear is bolted to the diff. Get in contact with Oak, he is our resident 3000 series guy.
Old 01-23-2016, 05:00 PM
If you look @ parts tree, #16 is the infamous bolts that go through bull gear #22
and hold things together, they are known to break/bend.
If you do a search here, there are several ppl that have had the same problem, and their adventures, some good, some not so good.
Now we might be totally wrong on your problem and I hope we are!
Good luck!!
Old 01-23-2016, 05:30 PM
Thanks for the quick replies, I took the rear fenders off hoping to see something obvious like broken linkage or something, everything looks normal, I started it up again and now it will creep forward real slow but no reverse, when I jack it up and hold one wheel and push the forward and reverse pedal the opposite wheel spins just like it should. It seems like I have to pull the differential and inspect it
