Go Back   Only Cub Cadets > Resources > What is it worth ?
Old 01-29-2016, 09:28 PM
knoxy_14 knoxy_14 is offline
Default Cub Cadet 71
theres an auction coming up here shortly and was wondering what would be a number i would be looking at trying to stay under here i see its got the sleeve hitch stuff wheel weights and thats all the extras i can tell if you can see anything else thats on it i would appreciate it
also theres not alot of these old tractors around here
1967 cub cadet 125
Cub cadet 102
cub cadet 71
Old 01-29-2016, 09:48 PM
I'm going to say to keep it under 200,that missing air cleaner may be an issue getting it to run.
Up to 534 and counting...
Old 01-29-2016, 09:54 PM
It looks like the air cleaner is missing, better check to see if the engine is stuck.
Wheel weights are worth $125.00 to the right buyer, three point hitch is worth $100.00 (give or take).
Look to see if it has a spring assist, and see if there is a creeper knob under the snow on the tunnel (doesn't really look like it does but check anyway).
If it has sat outside very long the trans-axle will be full of water, check to make sure the shifter isn't rusted stuck.
It looks pretty clean for the most part, might just be because it's sat outside for a long time though.
Good Luck
