Old 02-01-2016, 03:10 PM
biglefty's Avatar
biglefty biglefty is offline
Default 782 spool valve question
I may buy a dual spool valve for my 782 I was told it came off a 782. My question is I don't think the steel hydro lines that are on my machine now will work. What would be the best way to deal with this. The guy with the dual valve does not have the steel lines that went with that valve
Old 02-01-2016, 03:33 PM
If you have a flare tool and a tubing bender you can make new ones pretty easy.
Old 02-01-2016, 03:40 PM
biglefty's Avatar
yea guess your right, would those lines even need to be steel could you use another material that would bend easy?
Old 02-01-2016, 03:43 PM
Most people use 3/8" steel brake lines. The max pressure of the Sundstrand Hydro is 600 PSIG.
Old 02-01-2016, 04:03 PM
You also could use a combination of Steel Brake line and hydraulic hoses.
Old 02-01-2016, 04:10 PM
biglefty's Avatar
What do you mean by that George?
Old 02-01-2016, 10:57 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Or, you could just use hoses if your not into the cutting, flaring and bending thing. Its more expensive but lots quicker and cleaner if your going to do more than $hit on a plate so to speak
1- 1200 in pieces
1- 1864 in pieces
Old 02-01-2016, 10:58 PM
Rescue11's Avatar
No, not really...
1- 1200 in pieces
1- 1864 in pieces
Old 02-02-2016, 08:09 AM
You can use Brake line where convenient and hose where you have movement, that would require flexibility.
Steel Line is less expensive than hose and cleaner looking in most places,
and holds up better to usage over time.
A lot of hoses on them old tractors are now leaking.
one thing you will find impossible to do without dies, is tight bends.
easiest thing to get is a good tubing bender or pull the tubing around a ball bat in your vice.
but you are still limited to gentle curves/bends otherwise kinks will happen.
You can use 45* flair tools and it will work, but the hydraulic fittings are 37* flair, and do use them, not pipe fittings of copper furls
The hydro pressures are 6-800#
"Parker" fitting is a search word for fittings on ebay also TSC has a supply of common Hyd. fittings,as well as the usual, Granger mcmaster/carr etc.
Old 02-02-2016, 08:39 AM
No, not really...
Then what do they use.......????
