Old 01-26-2016, 04:55 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Originally Posted by Jeff122 View Post
IH Cub Cadet Parts on Facebook.
That's Yosemite Sam OCC sponsor page!
Gilles.
1963 100 (red)/in storage
Old 01-26-2016, 06:48 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
Yes. I found an old post that led me to it. Going to be a great time this end of winter, early spring. Lots of rebuilds and ad-ons for my 122.
Old 01-26-2016, 08:00 PM
You are only a 40 min. ride from me,so it looks like we will see you at the PA plow-day this April!
I have been to Newburgh,at the old Kawasaki dealer,by the motorcycle museum ,he had some cubs.
Up to 534 and counting...
Old 01-26-2016, 09:45 PM
That must be the delux kit cause I never get the mounting gasket either
That is a De-lux kit... and Jeff got my last one. I'll have more in about a week.
I simply cant understand why the carb to engine and air cleaner to carb gasket aren't included in a kit... If you rebuild a carburetor, don't you really want new gaskets to put it back on with???
Old 02-01-2016, 12:26 PM
Jeff122's Avatar
Default progress
I know you all like pictures. I made some progress this weekend. I installed the 3 point lift and fabricated some hitch pins out of 1/2" round stock. Just getting it into my workshop was a challenge. Next is a good cleaning, install the lower hitch plate and rebuild the carb. Then change the engine and rear end oils.
Old 02-01-2016, 01:53 PM
Looks good, nice work.
Old 02-08-2016, 08:20 AM
Jeff122's Avatar
If I need to change the gasket for the rear end cover plate, should I use gasket sealer?
Old 02-08-2016, 08:26 AM
I always do but then again I just use rtv with no gasket. I always clean the cover and rearend with a cleaning wheel on a grinder then put the cover on with permetex ultra black, I've never had a leak and its stuck on there so good you need a hammer and chisel to get it back off.
Old 02-08-2016, 11:19 AM
I have used dry gaskets, gaskets smeared with a very thin coat of grease and used gaskets over again, all with good results.
Within the past few years, I have grown to like Permatex® Form-A-Gasket® No. 2 Sealant. It doesn't get dry and hard, it cleans up easily and gaskets can be reused (if you're half way careful when you take it apart again).
I think it's probably more important to make sure the mating surfaces are clean and not damaged before you put it back together. I like to use the scotch-brite disks on a die grinder to clean them (but not on aluminum).
Old 02-08-2016, 11:23 AM
Jeff122's Avatar
Thank you all!
