Old 02-13-2016, 09:03 PM
Take the snap ring off.
Old 02-13-2016, 11:30 PM
bocephus1991's Avatar
When you check the end gap of the rings be sure their not cockeyed in the bore. You do have a ring compressor don't you? Careful not to score up the cylinder walls with the rod, or smack the crank with it and score it up. Don't wanna discourage you or anything, but if you think your in over your head have someone do this that has rebuilt engines before. It's very disappointing to spend all this money and time to have it messed up.
Brian
Old 02-16-2016, 05:30 PM
Bigsauce Bigsauce is offline
I started off with the intention of rebuilding the entire engine myself but the more I think about it, I'd rather have a pro do it just to have the peace of mind and not have to kick myself later if any issues arise. I should have the block back next week from the machine shop, I'm planning on painting the block with black engine enamel and leaving assembly for the most part to a small engine repair guy I know. I am also planning on taking apart my 105 and taking it to a shop to get the chassis blasted and powder coated before putting the rebuilt block in it.
Old 02-17-2016, 12:15 AM
That's a good idea. I don't want to discourage you and I'm not putting you down. I think it gives you more piece of mind that way.
Brian
Old 02-17-2016, 04:21 PM
I got the block back today! Talked with the machine shop owner, he seemed interested in me rebuilding it, he said he measured the piston ring end gap and it's in the proper range according to the Kohler manual. I asked if he could rebuild it for me, he told me he could but it seems like a simple rebuild and I should be able to do it myself. He was genuinely interested in helping me rebuild it and asked what I would need help with, and that if I get to a point in the rebuild where I'm not sure what to do I could just bring it in. He was very encouraging and now I'm leaning towards doing it myself again. I still have to order some parts so I'm gonna sit on it till then. Here are some pics of the block, I think it came out great.
Old 02-17-2016, 04:24 PM
Here's another pic of it
Old 02-17-2016, 04:41 PM
Did he grind the seats? Did you get him the new valves?
Old 02-17-2016, 06:12 PM
Yes and yes, also checked valve guides. The complete job included sonic clean/soda blast block, valve job, over bore/hone, adjusted piston end ring gap, checked crankshaft.
Old 02-17-2016, 06:14 PM
Cool.
Now, get it together and paint it!
Old 02-17-2016, 06:19 PM
john hall's Avatar
If you have an engine machinist willing to show you how to put it together, by all means take him up on his offer!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
