#61
Take the snap ring off.
#62
When you check the end gap of the rings be sure their not cockeyed in the bore. You do have a ring compressor don't you? Careful not to score up the cylinder walls with the rod, or smack the crank with it and score it up. Don't wanna discourage you or anything, but if you think your in over your head have someone do this that has rebuilt engines before. It's very disappointing to spend all this money and time to have it messed up.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
#63
That's a good idea. I don't want to discourage you and I'm not putting you down. I think it gives you more piece of mind that way.
#65
I got the block back today! Talked with the machine shop owner, he seemed interested in me rebuilding it, he said he measured the piston ring end gap and it's in the proper range according to the Kohler manual. I asked if he could rebuild it for me, he told me he could but it seems like a simple rebuild and I should be able to do it myself. He was genuinely interested in helping me rebuild it and asked what I would need help with, and that if I get to a point in the rebuild where I'm not sure what to do I could just bring it in. He was very encouraging and now I'm leaning towards doing it myself again. I still have to order some parts so I'm gonna sit on it till then. Here are some pics of the block, I think it came out great.
#66
Here's another pic of it
#67
Did he grind the seats? Did you get him the new valves?
#68
Yes and yes, also checked valve guides. The complete job included sonic clean/soda blast block, valve job, over bore/hone, adjusted piston end ring gap, checked crankshaft.
#69
Cool.
Now, get it together and paint it! |
#70
If you have an engine machinist willing to show you how to put it together, by all means take him up on his offer!
