Old 10-27-2015, 10:18 AM
ford4150's Avatar
ford4150 ford4150 is offline
Default 782 grill
I took this tractor apart a year ago. Took photos, but didn't take enough.
How is the top of the grille secured?
A photo would help a lot.
Old 10-27-2015, 10:26 AM
It's held in by 2 long springs that run down to the bottom of the grille housing.
Old 10-27-2015, 11:44 AM
ford4150's Avatar
Thanks olds. I'll look for the springs.
Old 02-24-2016, 07:17 PM
Llyodd Chrissmass's Avatar
Llyodd Chrissmass Llyodd Chrissmass is offline
Default Grille retaining springs
Hi can you take a photo of those springs and how the attach. I just bought two new oem springs as mine were long gone. The ends if the spring is different on each end. I dont want to force them on the wrong way.
Old 02-24-2016, 07:52 PM
The end that is square goes on the grill through the holes ,the udder end attaches to to holes at the bottom of the grill housing,see olds pic.
Up to 534 and counting...
Old 02-25-2016, 08:59 AM
Would this be the same for an 882 as well?
Old 02-25-2016, 10:30 AM
yes and you don't need fancy oem springs, just light duty screen door springs from your local hardware
Old 02-25-2016, 02:02 PM
Ok great ill give it a try. Btw I paid $8.00 a piece for these dang springs plus $ 4.00 shipping
Old 02-25-2016, 08:12 PM
Mountain Heritage's Avatar
Ouch!!
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 02-26-2016, 08:33 AM
SGragg SGragg is offline
Inactive Member
An alternative is to use shorter springs attached from the top corners of the grille to one of the multiple holes in the top, front corner of the side panel. Been using that method for years and works well.
Only drawback is that when both side panels are removed, the front grille will need to come out as well.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
