Old 02-28-2016, 11:14 AM
Originally Posted by BucknastyMiniRod View Post
Will a kohler command 18 fit in from a 2185? Or is it just the m18 I'm looking for?
It will but you'll need to rework the drive shaft or use one from a Cyclops.
The best way to do it is to use the drive shaft, muffler, heat shield, motor plate from an 1863 or 1864 and a pump adapter for the 5/8" round pump shaft. Jeff in PA makes the adapter.
Old 02-28-2016, 12:03 PM
BucknastyMiniRod BucknastyMiniRod is offline
Ok so if I had the complete tractor that the command is in I'd still need more pieces. I can pick that up with only 600 hours on it for 400 bucks.
Old 02-28-2016, 02:14 PM
$400 is a good deal for a good running CH18. Holler after you get it and I try to help you with the transplant. They list I gave you is the preferred way to do it but you have other less expensive options.
Old 03-01-2016, 06:05 PM
Ok so the tractor with the command 18 in it is closer to 700 hours on it. Needs a starter selenoid. How many hours can you generally get out of the command? Want to make sure this is worth doing. Or maybe I should just buy the 1200 with the little deck and sell off the 1711.
Old 03-01-2016, 08:04 PM
700-2000 hours depending on how it was run and maintained. $400 for a non runner, no way. Keep looking.
Old 03-03-2016, 03:59 PM
He says it runs just fine and can use the whole tractor as is just need to jump the selenoid. I'm not really interested in the tractor as a whole, I'd part it out or scrap it just use the motor. I still also really like the 1200 available with 350 hrs a snowblower and a deck for 500 but that's a tiny deck compared to what I'm used to.
Old 03-30-2016, 07:38 PM
Well it's been a long disappointing while. Missed out on the deal with the command. Really don't want to buy a new old mower with new issues and a small deck. I just stumbled on a kohler magnum 18. Not sure what it came out of. Runs good. A buddy of mine has it and will sell it for 100 bucks. Will this make an easy swap in the 1711?
Old 03-30-2016, 07:40 PM
I know it was replied that it's a good swap before but is there anything to check out if I don't know what it came from? Any differences pending on what it was used in?
Old 03-30-2016, 11:08 PM
See if you can get the Spec number off of that motor. That should tell us what it is off of and we can go from there.
