Hello everyone, this is my first post and I am not a Kohler or small engine guy.
My late 70's engine is in a bad place and I hope to save it with your help. The bolt that holds the governor cross shaft in came loose. I noticed the problem and tightened it up. I must have messed something up because now the engine starts but has what seems like timing problems when I give it fuel. Do you think I need to pull the whole thing apart? Or, is the some way to put the shaft back in the correct way without opening the case? Thanks, Paul |
First of all. Welcome to Only Cub Cadets. I do not have any knowledge on the engine you are working on, but someone with the knowledge will be along shortly. Again, Welcome.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
I'm sorry but I missed where you told us what you are working on.
Is it a cub cadet? what model? what size engine?. It might help as we don't like to assume anything, as too many variables. ![]() |
![]() Quote:
![]() Quote:
The cub cadet is a 1650 model. Thanks for the assistance, Paul |
The governor cross shafts is held in with a nut. The governor arm is held on with a bolt.
Now, what is it that came loose? You may need to readjust the governor. The Kohler K series engine manual tells how to do this. You can find it in our "Resources" section on the home page. It can be found under the heading "Technical Library, Tractors". |
Tags |
governor |
