Old 03-24-2016, 12:48 PM
Young Cub
Guest
Posts: n/a
Default Duals, do or don't?
I have my 125 cub hydro with a loader on it and didn't know opinions on duals? Traction, weight, how will the rear end handle? Basically worth it or not.
Old 03-24-2016, 12:52 PM
More tires= more traction.
Loaded tires= more weight more traction
Your choice.
Old 03-24-2016, 03:48 PM
Duels look pretty cool but they're a PITA to maneuver with.
Spend your money on a weight box.
Old 03-24-2016, 05:13 PM
Merk Merk is offline
I grew up on tractors with narrow front ends and duals. Never had any problems and they were a must when it comes to working ground.
When I build a loader tractor it will have 6-12s or 23-8.50-12 duals on it. Besides the extra traction the loader tractor will be more stable when the loader bucket is in the air.
A weight box in the rear makes the tractor longer.
Project Uncle Dick
Cub Cadet 70
Old 03-24-2016, 05:59 PM
longislandcubs longislandcubs is offline
I personally would have duals..
Old 03-24-2016, 06:01 PM
X2, I used to have them and they were cool.
Old 03-24-2016, 06:04 PM
Old 03-24-2016, 07:22 PM
The only way I would use dual rear tires is if I needed the flotation. Sometimes, it's best if tires work against the ground with lbs./sq/in pressure against the soil. In that case, skinny tires work better.
Old 03-24-2016, 08:08 PM
Young Cub
Guest
Posts: n/a
It mainly sounds like I'm hearing preference. It's there advantages and disadvantages.
Old 03-24-2016, 08:18 PM
Yes. Traction and stability.
