Old 03-24-2016, 08:19 PM
Bigsauce Bigsauce is offline
I decided to put the bearing plate on before painting the block. I measured the crank end play at .010. I'm going to put the piston/rod in sometime this week and then wait for nicer weather so I can paint the block.
Old 03-24-2016, 08:35 PM
Don't forget the end play on the camshaft.
Too loose and it will give you the "Kohler Knock Syndrome"
Old 03-24-2016, 10:41 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
that's usually the cam that knocks.
Old 03-24-2016, 11:06 PM
does anybody have a place to get shims that isnt 5 bucks each?
Old 03-25-2016, 06:49 AM
mickb72 mickb72 is offline
Default cub
Cam shims?( balance gear shims will work i think) Bearing plate? I think i have a few extra. Since you will be powder coating now, how about ceramic coating. Can you do that? I have a set of headers i need done. Mike
Old 03-25-2016, 08:08 AM
Yes I was referring to cam shims, when I looked them up on parts tree there $5.50 each which seems pricey for what it is.
Old 03-25-2016, 08:37 AM
Cam end play should be .005-.010. I'd try for 1/2 way between.
and the cam pin only goes in one way, the same way it came out, Important!
You are doing a major overhaul on an engine! And you are worried about spending another $5??
Old 03-25-2016, 10:38 AM
I was just wondering if anybody found a less expensive replacement so I could order several and have them on hand for future builds.
Old 03-25-2016, 11:58 AM
cubs-n-bxrs's Avatar
McMaster Carr has 10 packs for less than $5 a pack.
Old 03-25-2016, 12:53 PM
Do you happen to have a part number?
