Old 03-25-2016, 07:00 PM
coinman66 coinman66 is offline
Default 1250 hydro lever question
Just got a 1250 that I believe has sat outside for awhile. Haven't got it running yet. My question is the lever on the dash that makes it go forward and backwards won't move either way. Does tractor have to be running in order to move the lever or should that not matter. I sprayed all linkage inside the tower area with Kroil 3 days ago. If lever doesn't move, where do I go to next to check out?
Thanks
Old 03-25-2016, 07:11 PM
In short...NO
Check ALL the linkages from the handle all the way back to the Trunion Cam. Something is froze up.
Old 03-25-2016, 07:21 PM
Not sure where the trunion cam is, but I bet I can find it. I will trace all linkage down and hit it with some Kroil spray.
Thanks!
Old 03-25-2016, 08:27 PM
ford4150's Avatar
ford4150 ford4150 is offline
Cam is item 6 in diagram
https://www.partstree.com/parts/cub-...sion-controls/
Old 03-25-2016, 08:34 PM
budscub's Avatar
budscub budscub is offline
Default Brake pedal
Make sure your brake pedal is not locked down. That will prevent the lever from moving. when you depress the brake pedal the lever will return to neutral.
Good luck.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 03-25-2016, 09:00 PM
Well I feel like an idiot lol. The brake pedal spring is broke. Pedal was laying flat on footrest. Lifted pedal up and can now move hydro lever. I love this Cub website.
Thanks guys!
Old 03-25-2016, 09:33 PM
Thanks guys!
No reason for feeling like an idiot. You had a problem and asked. You got steered in the correct directions and now you KNOW it's an easy fix.
Jeff
Old 03-25-2016, 09:48 PM
Jeff
New to the Quietline series Jeff. Probably have lots more questions before it's over lol. Hope this 1250 is a good machine!
Old 03-25-2016, 09:55 PM
I'm happy with my two 125's but folks like the newer models too
Old 03-26-2016, 09:36 AM
johns cubs's Avatar
johns cubs johns cubs is offline
I Love my 124, but wish I would have kept my 105 for tilling! Now i have to find a creeper for 124 as its way too fast for tilling!
John
