Old 03-24-2016, 08:56 AM
gcrv1811 gcrv1811 is offline
I'm leaning toward battery. Did you put a voltmeter on it? If so what were the volts while running WOT?
Your lights will work, but still not have enough juice in the battery to start it.
Hopefully one of the grand wizards will come along with some other possibilities.
In the first video, the battery had been run completely dead. I went to Advance Auto and had it tested and the guy said it was dead and that I needed a new battery. I figured the tester would also test to see if it would hold a charge too and that was how it would determine if it was a bad battery... not the case.
After the battery had been charged yesterday morning (video below), I was able to get the 1811s lights to work and for it to turn the motor over. Now I am sure it is a charging issue.
Update Video to the Part 1 above.
In you first video you pointed to the solenoid and called it a starter, but you knew that, just a little confusion, right?
Honestly, I didn't know what it was but I have a feeling I will get to know this 1811 like I know my Jeep soon haha
Old 03-25-2016, 12:48 PM
aagitch's Avatar
aagitch aagitch is offline
Had some beet juice put in the tires this morning. Also installed the nifty xtreme tool box.
Adrian
2072 (789513)
Old 03-25-2016, 01:53 PM
Looks great, Adrian!
Old 03-25-2016, 03:06 PM
aagitch's Avatar
Thanks I appreciate it.
Adrian
2072 (789513)
Old 03-25-2016, 11:41 PM
Your 1872 is really taking shape. It should get plenty of use now. Tool box looks good, but being a cub, what tools could you possibly need?
Old 03-26-2016, 11:12 AM
aagitch's Avatar
Wish mine looked as good as yours. Thanks for the comment. That toolbox is for the other non Cubs during plow days so I can fix on the go lol.
Adrian
2072 (789513)
Old 03-27-2016, 12:11 AM
Thanks, but mine sure didn't start out like it ended... A lot of time and money, did I mention "money"? well worth the investment.
You've done quite a bit on yours to get it to your liking as well
Old 03-27-2016, 10:11 AM
Thems some meaty tars!
Looking good!
Old 03-27-2016, 11:29 AM
aagitch's Avatar
Looking good!
Thanks, it'll be my first time plowing with Tru-Powers. I've only used knock-offs in the past.
Adrian
2072 (789513)
Old 03-29-2016, 12:25 PM
j4c11's Avatar
j4c11 j4c11 is offline
Did my first mowing with the 2072 and 46GT deck. Power steering is really nice, and the turning radius seems better on the 2072 vs the 1450, even though it's a bigger tractor. Cut quality is great, but the deck is very loud, sounds like a jet engine about to take off. Overall, it's going to be hard to go back to a non power steering tractor for mowing.
