Old 03-29-2016, 08:32 PM
Mountain Heritage's Avatar
Default 42' blade on 782
So I used to have my blade on my 100, but with the manual lift it was getting painful to lift all the time with health issues. Not to mention I don't have chains on the 100 so pretty useless once the first skiff of snow arrived and the frost got in the ground. SO I decided to mount it on the 782. I was able to get a used sub-frame for a wide frame tractor. With a little modification to it I now have it mounted on the 782 the way I wanted it. The pockets on the back end of the sub-frame were not bottoming out on the rock shaft and almost to the point of they looked like they would bend the frame if it hit something solid. I didn't like it, so I got my daughter's boyfriend to re-weld the front quick attach pins and vertical pieces about an inch or so towards the front end of the sub-frame. It fits nice now, and seems like it will last a lot longer with no bends or mishaps.
Only problem I have is the bracket where the lift rod attaches to the blade is very close to the frame of the tractor. Is this normal? Is there another bracket I should be installing for the use of a 42" blade on a wide frame tractor?
I also need to make another lift rod for it since the one I had for the 100 is too long for the 782. As well it is a rod with two male ends, I need a female end at the back end to attach to the tractor and a male end at the blade end. Anyone have the proper measurements (and a picture maybe) for the lift rod, or should I just make one that is adjustable to be safe? I have an adjustable one on my 982 for lifting the 450 blower.
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 03-29-2016, 08:43 PM
The bracket your referring to is different between a nf and a wf, the one for a wf is longer so it clears the front of the tractor without hitting. Lew had a pretty good pic comparing the two.
Old 03-29-2016, 08:45 PM
LEW! Where are you and your show and tell pictures???
Mike
Ontario, Canada
Beware of the Wife
Old 03-29-2016, 10:36 PM
those are long gone...
Old 03-30-2016, 08:21 PM
I am disappointed Lew - you don't keep a library of photo's? All the equipment you have had over the years - you could start up a museum of just pictures of equipment you have bought and sold, not to mention the PARTS!
Mike
Ontario, Canada
Beware of the Wife
