Old 04-01-2016, 01:08 AM
sbybee sbybee is offline
Default 1914 lost reverse
Working on a nice 1914 that has been sitting a while, changed fuel lines and installed new front tires, ran fine, drove it around and after it went home backed off trailer and mowed good. Started up later and no reverse. Forward is fine. Drained hyd. fluid, looked ok but only about four quarts. Haven't cut open filter yet. New filter on order. Any suggestions? Manual on the way. thanx steve
Old 04-01-2016, 07:33 AM
Sounds like you have a problem with one of your Relief (Check) valves. As a suggestion, pull this valve out, clean it up real good, make sure the plunger has free travel, blow it out real good, then re-install. If that don't work, then I would suggest replacement.
Old 04-01-2016, 12:11 PM
Roland has already diagnosed the problem and remedied the situation quite well. Nice job, like always, Roland! It may be obvious, but I just wanted to put a reminder your way to clean around your relief valves before removal as to prevent any gunk from falling down into your hydrostatic fluid. Also, I had a 125 that had sat for quite some time outside, so after removing the relief valves I poured about a cup of hytran into the hole before replacement.
Old 04-01-2016, 02:27 PM
Terry C's Avatar
Terry C Terry C is offline
Wouldn't a 1912 have auto release valves?
I don't know much about that model.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-01-2016, 02:47 PM
Yes, they should be the auto type. I would remove them and put them back in the opposite hole. Then see how it works. If you loose forward speed pull them both and send them to:
605 Furnace Rd.
Conneaut Ohio 44030
Phone: 440-499-5813
Email: mark.machtech@gmail.com
*****We need pictures of that machine, they are pretty rare.
Old 04-01-2016, 02:52 PM
Ditto on what Oak said.
Old 04-01-2016, 11:57 PM
Default no reverse
Thanks for the info. I removed valves and seemed OK. Still working on it. steve
Old 04-02-2016, 12:26 AM
What do you mean by "seemed ok"?
Did you try and reverse the valves as Todd (Oak) mentioned?
