Old 04-12-2016, 09:14 AM
stagger JC stagger JC is offline
Default Moldboard Set-up
Hey All,
Attempted to turn over my Garden last evening to get ready for planting and had a very frustrating time. I using a 1250 to pull a 10" brinly with a sleeve hitch. I don't remember having any issues last season but, last night I could not seem to get the plow to engage the ground correctly. I followed all the set-up instructions again (alignment to the wheel width, landside is 1" off the ground, etc.) but it doesn't seem to want to suck into the ground more than 2"-3". If I adjust the share tip down for more suck, the landside sticks out of the ground and the plow tracks left.
Does anyone have any advice?
Old 04-12-2016, 11:14 AM
Did you try bringing the tip up? You may have the tip set too low.
Sounds to me like you need a new share. Post a pic of your plow share.
Old 04-12-2016, 11:40 AM
Inactive Member
Does a 1250 have a depth stop? The thing that you can adjust the height of your deck or any other attachment? Could you have that set to high?
Old 04-13-2016, 01:04 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
How wet is the ground? It's still too wet to plow here. If the ground is soft, you may want to go a little faster; at least that's what I was told.
Old 04-13-2016, 05:05 PM
aagitch's Avatar
aagitch aagitch is offline
If it plowed just fine the last time you used it, unless something's been damaged or worn out I would say it's the ground conditions.
Adrian
2072 (789513)
Old 04-13-2016, 06:31 PM
mmzullo mmzullo is offline
Why don't you come to PA plow day in PA and we can set it up for you. I assume your not using a coulter. But if you are take it off. How about the 2 bolts to stop
It from going L/R. Those bolts should not be tight against the plow. I leave it so the plow will rock 2 to 3 inches from side to side at the back. Pull the plow to the left side and it should be almost a straight line through the tractor. Which hole is the plow in middle L/R?
It's just trial and error but the time you dial it in the garden will be done.
Old 04-13-2016, 07:42 PM
Why would you do that? Do you not know what it's for? It has a purpose, and they plow much better with them on. You just have to know how to set one.
Old 04-13-2016, 09:38 PM
Merk Merk is offline
X2
Project Uncle Dick
Cub Cadet 70
Old 04-13-2016, 09:51 PM
homebuilt homebuilt is offline
ya if you've taken yours off and don't use it, I could use it. mines missing. those dang pumpkin vines are a pain when plowing them under in the fall!!
Old 04-13-2016, 11:20 PM
I'm not getting into a debate about coulters.
