Old 08-09-2010, 02:34 PM
kawicat kawicat is offline
Default super wheels and tire onto a 782D
Can Super rims and tires be directly added to a 782D?
Old 08-09-2010, 03:33 PM
Not if you want to be able to use any of your attachments. The deck will not be level and hit the tires, the front blade and snowthrower geometry will be all messed up, and you'd have to space up the fenders to get the tires to clear. It may also get harder to steer because of the larger front tires. The front tires may also hit the sides of the frame in a turn.
I don't understand why you want to do this...you only gain a couple inches of ground clearance and get a bunch of new problems...
