Old 05-08-2016, 07:50 PM
Job do Job do is offline
Default Gt 1554
I am new to this forum. Can I utilize your help in determining why my lawnmower isn't turning over? I thought it was the battery, and purchased a new one. When I turned over the key - nothing. What are my next steps? Solenoid? Starter? Would appreciate your help.
Old 05-08-2016, 08:06 PM
First, welcome to OCC....
Generally speaking, in order for the Starter to engage, the operator has to be in the seat, brake pedal depressed, and the PTO Switch is in the off position. Has that been done...???
Old 05-08-2016, 08:26 PM
Yes - brake engaged, PTO off, and in the seat.
Old 05-08-2016, 08:33 PM
Make sure the new battery is charged. Just because it's new doesn't mean it's fully charged, ask me how I know.
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
Check main fuse. Should be under the hood somewhere close to the battery.
Old 05-08-2016, 08:34 PM
Ok - how do you know?
I checked and it was at 12.7.
Old 05-08-2016, 08:44 PM
I checked two fuses and they are good.
Old 05-16-2016, 11:43 AM
Any other thoughts??
Old 05-16-2016, 12:24 PM
john hall's Avatar
Are your safety switches working? A switch may be bad, whatever mechanically compresses the switch may not be doing so (broke, out of adjustment). May have to just start tracing where you have current.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
