I have a 1211 tractor that I swapped an M18 into. I also changed the hydraulic oil and filter with Cub Cadet spec fluid. I used it to clear my driveway with the 450 blower a half dozen times this past winter. Now it's started leaking hydraulic oil under the rear end. I checked the level on the dipstick and it's a little high. Could it be just bleeding excess? I looked underneath with it both running and not running and I can't pinpoint where it's coming from since I also have a fluid film undercoating on it. It's not spurting out anywhere while it's running. It's leaking pretty good when it's parked though.
Otherwise we are just grasping @ long distance straws. Several places it could be leaking. You might get a better diagnosis that way.
As George said your best bet would be to clean the rearend as good as you can with some degreaser and a pressure washer to help pinpoint the leak, it will be much easier to find when it's clean and dry.
I doubt the problem is that the level is too high. Do what George says
cause there is no way to tell exactly where until it's cleaned. Common places are the relief valves and the cork gasket
Probably the relief valves. Mine seep. Wash it off good and see.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
