Old 05-10-2016, 10:01 PM
MattinmMichigan MattinmMichigan is offline
Default Crank and cam timing marks
I am having a hard time finding the timing marks . The crank I cannot find s punch mark on any tooth on the gear and the cam seems like the dot is right in the middle of the where if you turn the cam a hair either way it is gonna open valve right away
Old 05-10-2016, 10:06 PM
On ?????????????? What motor?????????
Old 05-10-2016, 11:05 PM
K 321 in a 149
Old 05-10-2016, 11:40 PM
The mark on the crank is a "dash" near the gear. It's cast into the crank
The cam should have a "dot". Should be in a "valley" of the gear.
Old 05-10-2016, 11:47 PM
[IMG][/IMG]
Old 05-11-2016, 12:28 AM
Yep. Just like that.
Old 05-11-2016, 11:04 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
you really don't need timing marks to put these together. put your cam in at split overlap then slide the crank in positioned at TDC.
Old 05-11-2016, 11:11 AM
Thank you very much for the help J-Mech !
Old 05-11-2016, 09:50 PM
K301 timing marks
click for larger view
or click this link
http://img.photobucket.com/albums/v7...d/DCP_4978.jpg
