Old 05-22-2016, 01:20 PM
Dodge71 Dodge71 is offline
Default Dip stick
When I start or shut off my mower the dip stick jumps up about a inch or maybe two. It looks to be maybe compression. Looked at end of dip stick, it had some mating on it, just at the tip maybe was hitting crank. I'm pretty sure its not normal.
Old 05-22-2016, 02:29 PM
mortten mortten is offline
Make sure your breather isn't clogged up.
Old 05-22-2016, 03:30 PM
Rmowl's Avatar
Rmowl Rmowl is offline
X2 on the breather. I got a 127 that had set for a while and got it running. Blew the dipstick out and a lot of smoke. The breather was clogged up with a nest from a mud dobber. The breather cover is on the carb side of the engine.
-Rick
IH 782
IH 126
CCC 1863
Old 05-22-2016, 07:57 PM
OK I'll look for the breather and see if its clogged
