Old 06-03-2010, 10:42 AM
bvanzalen's Avatar
bvanzalen bvanzalen is offline
Nikster, you do it first, make all the mistakes, post the right way to do it, then I'll do it...deal?
Bob VanZalen
1974 Cub Cadet 169
Old 06-03-2010, 01:04 PM
BajaGTO's Avatar
BajaGTO BajaGTO is offline
I just changed mine.
But I did it during my engine swap so getting the drive shaft off was easy.
I believe on the quietline series you have to undo the engine from the cradle and slide it forward to get the driveshaft out.
-Ted
Old 06-11-2016, 09:28 AM
cubboy1 cubboy1 is offline
Default cooling fan on cub 1250
I was reading these posts on how to replace the fan and found on youtube a guy who used a fan blade from an appliance that slips over the shaft using a collier he made to attach to. Looks like a great time saver and a better repair. the only thing is I cannot find this fan blade. Does anyone have any suggestions as to where to find this blade? The guy on youtube does not respond to requests.
Thanks
Old 06-11-2016, 10:09 AM
I've been trying go find an aluminum replacement option for my hydro cubs as well...especially when I had just bought a new OEM plastic one and it broke when it fell from 10" above the ground...I think the best bet will be a dehumidifier/humidifier repair place...the one in my 1974 monkey wards (gilson bros) is aluminum and attached to a larger split collar...I've been looking around.. Found a place, just waiting on size, blade angle, etc...
Good luck
Old 06-11-2016, 10:57 AM
No need to undo the engine in a Q/L to replace the fan.
Just follow the procedure as stated in the manual.
And while you are at it, you may want to replace the rag joint(s) also at this time if they are deformed and hard as a brick. When they are in that condition, it adds to driveline vibrations, not good.
