Jason, it looks like that cylinder that is welded on your bracket would hold a lift bar for a blade or snow blower, so you may want to leave that on for that kind of attachment. Also, there is a 48" CC123 deck on e-bay (search cub cadet 123) for about $100 and I think that it is in your region (California). I know a guy who has stacks of them, but shipping would probably kill you to get it from Indiana. I've retired mine from mowing (I have a commercial cub zero turn for that) and so my 123 is used for moving my 42" blade for moving mulch or snow and for my 36" snow blower. I hope that you locate a deck soon.........my 123 did do an awesome job at mowing and as you already know, gave a smooth ride!!!
Merk.....thanks for the extra photos on cutting that lift arm down....gulp!!! I can't believe that I am going to cut an original part......this one might hurt and even leave nightmares, but it is for the best I keep telling myself!!!haha..... Cub Cadet 123 ![]() |
Okay. I drilled my holes in my frame, attended the tractor and small engine show where I purchased a new lift assembly and now I am stumped on spacers. I read in the manual where I need to have spacers between the frame and hydraulic mounting bracket (holds & supports the hydraulic unit-not cylinder). What size spacers are they 1/2" would be my guess, but I do not know for sure.......anybody else know? Also, I cut my deck lift support off at the correct height, but where do I get that extra bracket that the cleavis attaches to? Is that my old bracket, but modified? Or am I missing a part that I need? Suggestions??? Thanks in advance for the pictures and help!!!! I need to take some pictures and post....don't I? Sorry. I just never think to do that and I'm about 40 miles away at this time.....Yikes!! Hopefully someone will realize what bracket I am talking about.
Height = .750 Width = .875 ID = .405 |
Thank you RPalmer for the specs. and great photo!! Do you happen to know anything about the lift arm? The manual says "new lift arm". Is that my old lift arm reworked or do I need to acquire a new lift arm for it?
Thanks!! Cub Cadet 123 ![]() |
Cub Cadet 123,
The part you need to weld to your modified lift arm (rock shaft) is NLA. No Longer Available. However you can find the rock shaft with that part already welded on it from one or more of the sponsors listed here. Matt G. just sold one a few weeks back. They are available. While you are checking on parts make sure you have the pump adjusting bracket. It is what allows you to put tension on the pump's belt. I hope this helps. |
Thank you once again. I will post in the Wanted menu and hope for the best. If you know of anyone, then please let them know of my need to acquire this part.
With much appreciation, Cub Cadet 123 ![]() |
old thread , but new to me.
is there a pdf manual for this pump? for the parts and belt size and what not...?
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
![]() Quote:
Mark ![]() 1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights 1967 Model 102- mower 1965 model 70 - weights,rear lift and spring assist Model 100 resto mod project, rear PTO, hydraulic lift QA42 snow thrower 42in front blade Grandpa's F-12 and Super M |
![]() Quote:
I remove my lift ratchet and lift ratchet spacer assembly from my 100.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
I will have to try that just trying to get a little info before I go cutting up stuff. Thanks for the info.
