Old 08-17-2010, 10:47 PM
bradm bradm is offline
Default 1872 steering problem
need help - driving my 1872, oil started pouring out from underneath the steering wheel. After researching it is clearly is coming from the column. Power steering works fine, hydro is working.
Any help is appreciated.
Old 08-17-2010, 10:55 PM
squatch squatch is offline
The column can be rebuilt. The parts ain't cheap and I've been told by several parties that the results aren't guaranteed. You also need a detailed instruction document to do the job. It's part of the service manual. I just bought a good used column for mine when it acted up. You don't even want to know the price of a new one.
Try one of the site sponsors they may be able to help you with a column. If not we can point you to other sources.
Old 08-19-2010, 08:34 PM
raboley raboley is offline
I just had your same problem and rebuilt my steering column on my 1872. I have about 3 hours of use on it and no problems so far. Couple of main things to remember. You need a clean area, be very organized and take your time! Absolutely get the rebuild manual which you download. I even downloaded the OEM maker version (Parker) as well. The manuals are very similar with some minor differences.
I paid $70 for a kit from John Deere. The kit was AM107078. From what I've been told from people who know, Cub Cadet, JD (430, 332, 318) and Simplicity Sunstar interchange. Not an expert, so don't take my word on it, but something to think about to save some $$$$.
The worst part of mine was extracting the steering wheel which I ended up replacing from Steiner.
Old 08-19-2010, 11:28 PM
That's great info! when I priced the rebuild stuff from cub it was almost as high as a used one.
