Old 07-16-2016, 10:22 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Looks great! Keep the pictures coming. Where did you find the radiator hoses?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 07-16-2016, 10:37 PM
Frank, I'm thinking some people are using a Kubota RTV(Utility Vehicle)hose and cutting it but I can't remember where I saw that.
Old 07-17-2016, 12:03 AM
DieselDoctor's Avatar
Here's what I used after finding this information in the engine section of this forum.
Upper radiator hose, Cub part# IH-1286631-C1 / 735-3020
suitable replacement: Kubota part# K7311-85150, made for the Kubota RTV utility vehicles.
The 7311-85150 hose has a 3" long "bell" section at the radiator end of the hose to accommodate a bigger radiator outlet. You just cut this bigger end off and the remaining piece is a perfect fit.
I bought mine from Kubota Parts Depot for $22.55 plus shipping. As for the lower hose, so far discussion has been to use 7/8" heater hose, but it is hard to locate. I am toying with the idea of having heavy wall tubing bent and use straight rubber hose to couple at each end. I may also try to find pre-bent shapes and weld them together. I've built headers for performance cars and this would be a similar process. If I do, I'll post pictures and list the components. Stan
Old 07-17-2016, 10:39 AM
what kind of prep for paint did you do on the engine?
I will be pulling mine soon and I may paint it,not sure...
Old 07-17-2016, 10:46 AM
Looking good!
Old 07-17-2016, 10:48 AM
Looking good!
Old 07-17-2016, 11:21 AM
DarkMinion - after removing the D600 from the tractor and sub-frame, I sealed all the openings and thoroughly hot water pressure washed the entire motor. Next step was to use a small wire brush in a drill to knock off any peeling paint and loose scale that I could reach without tear-down. After another quick rinse and blow dry, I painted the engine using genuine Kubota paint purchased on E-bay. $11.99 a can, and didn't use half the can. The paint covers exceptionally well and drys quickly with a nice shine.
Old 07-17-2016, 12:23 PM
Bugjunkie66's Avatar
Bugjunkie66 Bugjunkie66 is offline
Great job on the engine, looks great in fresh paint!
What are your plans for the wiring harness? I'm working on an 882D now and the wires are brittle and cracked. My thought was to replace each one with an identical new wire of the same gage and color. Its going to be a long haul!
I'll enjoy seeing your new updates as you progress.
Steve
149 with #2A Tiller
169 mowing machine
1864 with 3pt hitch & 54" GT deck
Haban Sickle Bar
DB moldboard plow
Brinly #10 plow
1959 DB Suburban with 3pt
882D with 3pt and front remotes - "in progress"
Old 07-17-2016, 12:34 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Your doing a great job, that's a cool tractor! FYI I just finished up a D650 in a kubota tractor and got parts from kumar bros, great customer service. Looking forward to seeing it all wrapped up!
-Rick
IH 782
IH 126
CCC 1863
Old 07-17-2016, 03:29 PM
Here are a few options.
I would check with Mike first. His stuff is top notch.
http://www.onlycubcadets.net/forum/s...ad.php?t=34457
More options.
http://www.porchelectric.com/ihcub.html
http://www.cngcoinc.com/pages/custom.../Product/51439
