Old 08-19-2010, 11:34 AM
ihnick's Avatar
ihnick ihnick is offline
Default pto clutch with a brake assembly
i forgot how this goes on. the snap ring and washer go on the outside right? or does it just float on there? couldnt tell by the pictures in my service manual
Nick.
Old 08-19-2010, 01:02 PM
Snap ring and washer go on the outside. How would it function if there was nothing holding it on?
Old 08-19-2010, 01:28 PM
ihnick's Avatar
That's what I thought. there was some wear on the inside so I thought I would check
Nick.
Old 08-19-2010, 01:30 PM
You might want to make sure that the brake fits good on the clutch if that's the case. If it looks like was spinning before, something might have worn out that caused it to do that. Are the 3 tabs on the brake disc worn too?
Old 08-19-2010, 02:03 PM
ihnick's Avatar
i guess i didnt really look that close. could i convert the brake system to the old style system?
Nick.
Old 08-19-2010, 03:14 PM
hydrocub hydrocub is offline
yes , you can change to old style
