#41
![]() Quote:
dont use drill to get a 1/8 pin out ..no no as others have said... ![]() get 1/8 pin punch
Frank __________________ IH 982 , 3 point CCC 782 ----------------------- ![]() |
#42
![]() Quote:
![]() I know, I know I'm a big Starrett fan boy but since it's American made and they still do the job after more than 20 years in my tool chest, maybe I'm right this time ![]()
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
#43
Gilles ....your tools look like they have never been used in 20 years ...you should see mine
![]() ![]() ..been in my toolbox since 1968
#44
I have a 1/8 pin driver. What is the best way to support the input shaft? I could put everything back together and then support it with the jack again. The ends were broke because there was so much movement on the coupler. Now there just a piece left in the input shaft. I have been soaking it with Pbb blaster as well.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
#45
Also, I have a 1864 drive shaft and cv joints on the shelf so would that work in the 1872 with the proper adapters?
#46
![]() Quote:
#47
Yep, I think that would be best. I will try it Friday. Thanks.
#48
I was also wondering which cyclops driveshaft would work on the 1872
Adrian 2072 (789513) |
#49
No matter what shaft you use, the length will have to be adjusted. I believe no matter what, you have to make it longer. Whether it came from an SGT or not. You can use one from any machine, if you make the length correct.
#50
Shaft from an 1882 is a bolt in, you'll need the CV pump adapter (JeffinPA) and you'll have to drill and tap the pump input shaft.
