I'm reinstalling the pump and trans axle in the 682/782;
When the 4 bolts mounting the pump to the trans axle came out they appeared to have thread lock on them, correct? and torque to 30fp according to the service manual? Then the 4 bolts thru the frame into the axle let fluid out when removed, anything that needs to go on them before they go back in to help seal or thread lock? and torque to 30fp? Thank you, Vic |
None of them need torqued. Just tighten them up with a rachet or a wrench.
No thread lock necessary. They should all have lock washers on them. As far as sealant, no. I put anti-seize on them. |
I use Permatex #2 on the bolts that go into the oil sump. After I stripped one of my 882's holes with a 3/8 ratchet I also torque them to 30fp as per the manual because I'm not good at judging tightness.
This site is so kool, thanks guys!
