Old 07-05-2016, 10:02 PM
mike.beccue mike.beccue is offline
Don't quiet understand that posted upside down...... last picture was fine. Lol. Just a kubota z482. Fits well in the frame with little modifying here and there. Free running diesel I figured what did I have to loose.
Old 07-16-2016, 10:35 PM
budscub's Avatar
budscub budscub is offline
Default 1650
Sprayed a little 935 Iron gard on the White parts. Unfortunately no pics. I just painted the backsides of everything for now. Looks like a little wet sanding later when it all cures out.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 07-17-2016, 09:46 AM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Pulled the old hydraulic line off the 149. Pulled the PTO and disassembled it.
Getting ready to order some parts to fix the PTO and hook up the new (old) hydraulic line.
Also got the driveline for the 1200 put back together. Hopefully I'll get it installed next weekend.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 08-17-2016, 06:52 PM
twoton twoton is offline
Painted my block with some of this stuff;
http://www.eastwood.com/ceramic_engine_paints
Old 08-17-2016, 09:14 PM
Looks good there twoton! Ceramic paint.....I need to look into that. Thanks, TB
Old 08-17-2016, 09:18 PM
Default 1450 Hydraulic Control Valve
Hosed down the stuck hydraulic control valves again with pb blaster. Work your magic before I have to persuade you! TB
Old 08-17-2016, 09:47 PM
Looking good!
Old 08-18-2016, 02:20 PM
Looks like everyone is busy with their cubs....
Brought home my 72 from my brother's,in storage for the last few years, filled the tank,pulled
the choke,started in 3 pulls,time to cut some grass,but first some pictures.
Old 08-18-2016, 09:59 PM
Good looking 72, Lew!
Old 08-18-2016, 11:35 PM
That right there Master of Lew is a purdy 72.
Good talking with you this afternoon.
