Old 08-22-2016, 10:46 AM
mickb72 mickb72 is offline
Default c
Looks good, should work. Might need some training wheels to go straight. Mike
Old 08-22-2016, 10:26 PM
PSully PSully is offline
It pretty much worked as expected. It could have used some more weight, but if I reached back and put a little pressure on the weight disk, I could get the blade to sink in pretty good. I made a bunch of short passes going 90 degrees as well. the roots are pretty stubborn, but for the most part, I'm gaining on it.
Old 08-22-2016, 10:45 PM
Plows are made to suck themselves into the ground. If you put a "hook" on the end, you won't need any weight.
Like this:
