Old 08-22-2010, 05:06 PM
rlcyran's Avatar
rlcyran rlcyran is offline
Default Trunion Bracket
Can someone look at the picture and tell me are the trunion bracket and speed bracket suppose to come off separate? and are they suppose to move freely from each other. Because there both stuck together and I don't see how the trunion with the springs work if both brackets are like frozen together. and is there a manual someone can guide me to so I can readjust my neutral position so my tractor wont creep forward?
Thanks!
Old 08-22-2010, 10:11 PM
Your trunnion doesn't look at all worn, everything you need to know should be in the Technical Library - Tractors, section on this page http://www.onlycubcadets.net/forum/index.php
Old 08-23-2010, 08:39 AM
aagitch's Avatar
aagitch aagitch is offline
From the angle of the photo I agree with Sam it looks like it doesn't have any wear to it. Those springs look pretty rusty though so I would replace those. Go down below your circle and there's a snap ring. There's some other snap rings to take off also. The manual will help.
Old 08-23-2010, 09:00 AM
Those two pieces are supposed to rotate on each other. Remove the snap ring on the end of the trunion shaft. I think you also have to remove the E-clip that holds the other cam plate on, and then you can pull it off and clean up the area where the trunion shaft passes through.
More info
Neutral Adjustment
Old 08-23-2010, 02:34 PM
rlcyran's Avatar
Thanks for everyones response.
