Old 09-07-2016, 08:34 AM
Default Power angle cylinder
Since I'm almost done adding dual hydraulics to my 1211 I guess I need to start figuring out the ram for the plow, I need to know the rod diameter and the stroke of the factory ram so I can begin my search. Thanks
Old 09-07-2016, 08:56 AM
1.50" Dia by 7.50" stroke.
Old 09-07-2016, 09:13 AM
Excellent, thank you.
Old 09-07-2016, 10:14 AM
IMHO, that 1.5" Diameter of the rod shaft is a bit excessive but have no technical data to re-enforce my suspicions.
Old 09-07-2016, 11:24 AM
I agree, that does seem like a bit much. I would think 1" would be plenty.
Old 09-07-2016, 11:41 AM
100% agree.
Old 09-07-2016, 12:34 PM
My guess is that the bore is around 1-1/2" but the rod is smaller. Here is another thread that has more dimensions.
http://www.onlycubcadets.net/forum/s...ad.php?t=34040
Old 09-07-2016, 12:46 PM
This looks pretty close. You may need to move one of the attachment points to accommodate the slightly longer stroke. I'd move the point on the blade outwards a bit. Should be an easy thing to deal with.
http://www.surpluscenter.com/Hydraul...S-9-7258-8.axd
Old 09-07-2016, 05:29 PM
As long as the cylinder moves the blade angle from full left to full right, it doesn't matter if it's "centered".
Old 09-07-2016, 08:55 PM
darryljs's Avatar
darryljs darryljs is offline
Don't know if this helps, but this is what I used for a power angle cylinder on my 125. Works good, even in dirt and stones. Wheel Horse Tractor Mower Hydraulic Lift Cylinder (it's the red one) Find them on Ebay.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
