Is the transmission and rear end all one unit on the 102?
I had to drain the Trans fluid to change the Pinion, and it was as thick as honey, also pulled the lower plug on the differential and drained whatever I could. I would hate to go through all this work and not ask this stupid question rather than find out the hard way. I also happen to notice that Traveller Universal Tractor Trans/Hydraulic Fluid is on sale at Tractor Supply $11.99 per 2 gallon container. |
Yes it's all the same cavity, the traveller fluid will be fine
Great....Thank You very much....
