Old 08-23-2010, 07:38 AM
mernestm mernestm is offline
Question Cub 2135 Starting Problem
I have a Cub Cadet 2135 that no longer turns over. The battery has power since the headlights and and the gauge lights on the dash work. I replaced the key switch two years ago and recently when starting it, sometimes it would turnover and other times it would not. When that happened, I would turn the key on and off repeatedly and eventually it would connect and start.
From the research online it seems like it could be a safety kill switch, starter, solenoid, or a loose wire connection somewhere. I was hoping this forum might have some suggestions on how to go about testing and fixing.
Thanks!
Michael
Old 08-23-2010, 08:13 AM
Which model do you have...???
Old 08-24-2010, 11:13 PM
Default 2135 starting problems
It is the second model listed. Serial number 000345136.
Thanks!
Nichael
Old 08-25-2010, 06:49 AM
Check your E-Mail. Wiring Diagram sent.
Old 08-25-2010, 10:41 AM
TEET's Avatar
TEET TEET is offline
I had a 2135 a few years back, with the same symptoms. It ended up being the safety switch under the seat. I jumpered the leads together....problem solved!
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 12-11-2011, 11:14 AM
Vashon Vashon is offline
Default Model 2135 starting problems
I have a 16 year old Model 2135 Cub Cadet Lawn Tractor. Great machine.
Using it last wee and it just stoppped running and wouldn't re-start. Cranks fine- no start.
Good new gas.
Changed fuel filter
changed spark plug
cleaned carb
Still no start
Hoping it's not electrical
Anyone have any ideas
Old 12-11-2011, 02:19 PM
Vince_o Vince_o is offline
Heres a start to your problem. If its turning over, all the safety switches are working. That my friend is 90% of the problem. All thats left is air fuel and compresion, them the easy stuff.
Check your choke plate, I have one here in the junk pile that has the same problem. If you hold your hand over the carb it will start and run all day.
Tags
electrical, solenoid, starter
