Old 09-24-2016, 09:10 AM
ambrola's Avatar
ambrola ambrola is offline
Default Sediment Bowl
What's the proper way to tighten the sediment bowl on the gas tank? When I screw it in, it's not tight, but you can't go another complete turn. It is leaking because of this. I just noticed this yesterday, when I saw gas on my new paint. The paint wasn't hard enough, and it just rubbed off. I know there's a way, but I can't figure it out. BTW, this is on my O.
Old 09-24-2016, 09:27 AM
cubs-n-bxrs's Avatar
There should be flats next to the threads to put a wrench on. The threads are aluminum and you should be able to get another turn on it with a wrench. Make sure to thread tape it as well and wrap the tape in the direction of the threads otherwise it will just unwind the tape.
Old 09-24-2016, 09:39 AM
ambrola's Avatar
Yes, I can get a wrench on it. What kind of tape do you use?
Old 09-24-2016, 09:43 AM
Teflon thread tape . Any hardware store will have it. It's about a buck a roll. About two full wraps with the tape and you should be good to go.
Old 09-24-2016, 10:17 AM
ambrola's Avatar
Thank you very much. Can't ruin anymore of my new paint. When tightening the bowl, there's not a chance of messing the gas tank up are there?
Old 09-24-2016, 10:29 AM
The only way you'll hurt the tank is if you over tighten it.
Old 09-24-2016, 10:32 AM
ambrola's Avatar
I think the tape will help a little. I will just have to drain the tank, and take the bowl off and try again.
Old 09-24-2016, 04:14 PM
When you wrap the teflon tape make sure you wrap it tight and wrap it in the direction the threads are going.
Old 09-24-2016, 04:36 PM
ambrola's Avatar
Thanks, I will.
Old 09-24-2016, 08:27 PM
Thanks, I will.
Also make sure the tape doesn't cover the bottom of the hole where the gas comes out.
