Old 09-22-2016, 06:24 PM
mhasewinkle's Avatar
mhasewinkle mhasewinkle is offline
Looking great!!
Mike
70, 71, 72, 73, 100, 102, 125, 124, 128, 147
1200, 560 Farmall, 340 IH, #2 cart
Old 09-22-2016, 08:19 PM
cubcadetguy123's Avatar
cubcadetguy123 cubcadetguy123 is offline
Thanks guys! I finished painting yellow tonight with the gas tank. I hope I can start her this weekend.
1970 Cub cadet 73
Old 09-22-2016, 09:59 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
WOW that is looking really nice!!
Keep the pics coming!!
Jay
Proud owner of the following:
Old 09-22-2016, 11:24 PM
Looking good!
Hint... The baffle on top of the head goes over the flywheel shroud.
That's not a "hint", you told him the answer.
You're doing a fine job, looks great.
Old 09-24-2016, 12:13 PM
tbone tbone is offline
Looking real good.
Old 09-26-2016, 08:36 AM
Here's a little update. We fired her last night and it ran amazing. Started in 2 cranks. After we shut down, and looked around. There was a puddle of oil on the frame and the floor coming from the front oil seal. Now I know this should be in the engine section of this site, but I'm still going to ask. Where should the oil seal sit? Should it be flush with the block or a 1/2 inch onto the block. It's a k161 bored to k181 specs.
1970 Cub cadet 73
Old 09-26-2016, 11:36 PM
Pretty much flush. NOW do you mean the front of the tractor front seal, or engine which is the rear of the tractor?
post images
Old 09-27-2016, 07:43 AM
It's the front of the engine seal. The pto side.
1970 Cub cadet 73
Old 09-27-2016, 01:10 PM
RedHawCadet RedHawCadet is offline
looking good! What paint did you use?
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 09-27-2016, 07:03 PM
I used almost 2 quarts of shop line paint with hardener.
1970 Cub cadet 73
