Old 10-10-2016, 04:17 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Default Help with 149 Push Blade
I tried to install the blade on my 149 today and I can't figure it out.
I think the PO added something to it. Looking at the installation instructions, I think he added something to the piece that goes on the QA latch. There is an extra link, and when I put it on the QA latch, it barely lifts off the ground.
Also, he gave me 2 front frame pieces, any idea why? It doesn't seem I can use the other frame on the blade setup I have now.
Anyone have pics of their blade, off the tractor?
How long is the pull rod? Mine seems short, but then again I don't think I'm installing it right.
Finally, does the sub frame go on the inside or outside of the frame on the footrest bar?
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 10-10-2016, 04:26 PM
JLM78 JLM78 is offline
The snow plow is for a narrow frame . I don't know what that bar is for that's not stock.
Old 10-10-2016, 04:42 PM
the plow you have pictured is for a narrow frame tractor and you have a wide frame tractor, i'm not saying if wont fit but you will have to do a pretty good amount of modification.
Old 10-10-2016, 05:07 PM
Merk Merk is offline
The blade is for a 70-100-71-102-122-123.
The extra part looks to be for a Simplicity tractor.
Project Uncle Dick
Cub Cadet 70
Old 10-10-2016, 05:34 PM
vr4Legacy's Avatar
DOH!!
I guess that's why I couldn't get it to work....
Not sure I want to bother modifying to make it fit. And to think, that's the only reason I even found the 149... I was looking for a blade for my 1200.
Thanks for the quick replies.
It looks pretty close to the one in the manual I have.
File Type: jpg Screen Shot 2016-10-10 at 4.36.34 PM.jpg (13.4 KB, 190 views)
File Type: jpg Screen Shot 2016-10-10 at 4.36.47 PM.jpg (19.0 KB, 189 views)
-Jason
Old 10-10-2016, 10:40 PM
sawdustdad's Avatar
All you need to do is replace the subframe to get it to fit either your 149 or 1200. Others may be interested in your narrow frame subframe. Everything else about the blade is interchangeable.
I sometimes make my own lift rods from 1/2 inch steel rod, bending it with a torch. there were various lengths, IIRC, not sure what exact length the 149 used. Somebody here has previously posted the various lengths and which tractors they fit.
Old 10-10-2016, 11:14 PM
RedHawCadet RedHawCadet is offline
Here you go http://www.onlycubcadets.net/forum/s...ead.php?t=2888
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 10-11-2016, 09:29 AM
vr4Legacy's Avatar
Thanks! Looking at the manual, it looks like there are a couple bends, and the front QA part is a little bit different. Hopefully I can find a subframe cheap enough. I don't want to spend more on a subframe than I did the whole tractor lol.
Originally Posted by RedHawCadet View Post
Thank you, I think I've read that before, but thanks for the link. That helps!
-Jason
