Old 10-09-2016, 09:54 PM
Cool New "old" tool for my other hobby
One of the guys on a vintage forum ended up with this tool for cheap and posted a what is it? question and also asked if anyone needed it.
I knew exactly what it was and asked what he wanted for it. $20 plus shipping made me the happy owner of a crank pin turner.
The old engine have babbitt bearings and although they aren't real fussy as far as size, they do have to be round. When the crank throw wears out of round, the tool with the correct width cutter is placed on the crank throw and turned around to make the throw round again.
Old 10-09-2016, 10:43 PM
congrats on the new tool Jeff, new tools are always the best.
Old 10-10-2016, 08:01 AM
That is cool.
Old 10-10-2016, 09:04 AM
That's cool Jeff.
So, does it cut it, or are those stones that "grind" or file it?
Old 10-10-2016, 02:46 PM
That's awesome, Jeff!
Old 10-10-2016, 08:47 PM
That's cool Jeff.
It cuts. They are high speed steel cutters.
Old 10-10-2016, 08:52 PM
john hall's Avatar
Never seen anything like that, cool! I assume it works kind of like a tubing cutter? I guess you just quit cutting as soon as it goes round? I would think the surface finish would have been horrible, is polishing afterwards required?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-10-2016, 08:59 PM
Surface finish is dependant on how well you sharpened the tool. Yes, once it's round ,you're done cutting. Surface finish can be improved with emery if needed.
The "saving grace" on this type of repair is that babbitt bearings are used. They work great as they form to any minor imperfections on the circumference of the throw. ( it must be round or the babbitt gets "pounded" out )
Old 10-10-2016, 09:09 PM
john hall's Avatar
I've adjusted a few babbit crank bearings and will be honest, I never bothered to mike the shaft, just measure and remove shims until things got tight then added some back. Do you know if this was something more popular with auto engines than tractor and stationary engines? I'm thinking the "farm stuff" was ran slower and maybe more forgiving. I guess real repair shops may have been the ones using them, as crank grinding machines were few and far between. Certainly a cool item! I work with a guy who's father just retired as an engine machinist. Next time I see him I'll ask if he ever heard of one of these.
2072 w/60" Haban
Old 10-10-2016, 09:30 PM
The patent date is April 4, 1922 on this cutter. Almost all the engines used babbitt back then. High rpm wasn't used since babbitt can give up quickly under heavy load. ( keep in mind that when you double the rpm, the centrifical force quadruples. )
