Old 10-18-2016, 12:05 PM
Default Broken JD
The guy that cuts the hay at my place broke his JD 6300. This is the second time he has had this happened to him this year. He pulls the bailer with the 6300. It has 4 wheel drive and what has been happening is that grass gets wound up around the drive shaft for the front axle until it has so much grass around the shaft that it breaks the oil filter for the transmission off. Very poor design. I spent about an hour the other day just cutting the hay off the shaft and still have more to do. Grass was wedged in so tight between the shaft and bottom of the frame that I had to disconnect the drive shaft from the front axle. Pile on the ground is what I have removed so far. Just trying to help the guy out. Think it needs some sort of belly shield.
Old 10-18-2016, 12:18 PM
Wow, that's not good!
Old 10-18-2016, 12:22 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Does the shaft still spin if its in 2wd? I'd say leave it off if it doesn't. You do have some pretty steep hills though.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-18-2016, 12:29 PM
john hall's Avatar
We have been having trouble with the PTO shaft on the rear mount sickle mower wrapping this year at the tractor. It takes a while to cut all of it off. I could see it tearing a seal out or damaging the U-joint.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-18-2016, 12:49 PM
Terry C's Avatar
Terry C Terry C is offline
That thing needs a belly pan or some kind of guard like you said lot of important looking hoses there plus the filter
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-18-2016, 01:42 PM
Seems that JD would have designed a cover to protect the moving parts.
Old 10-18-2016, 03:38 PM
Yep the front axle turns it even in 2 WD
Old 10-18-2016, 03:42 PM
Of course the nipple that breaks of is aluminum it's part of the housing and it's only $340.00 for the housing. Thinking a piece of conveyor belt from the local quarry hooked to the front of the tractor and hanging from some chains at the rear may work. Feel bad for the guy, he's struggling to make a few bucks selling hay.
Old 10-18-2016, 03:49 PM
Dirty Steve's Avatar
Certainly agree about poor design. How tall is the hay? I like the piece of belt from chains idea.
Old 10-18-2016, 04:40 PM
Steve they rake it into a windrow, then the tractor pulling the bailer drives over the windrow to feed it into the bailer. The pile is about up to the front axle. Not much they can do to change this that I know of.
