Old 10-18-2016, 04:44 PM
Seems that JD would have designed a cover to protect the moving parts.
AC they did design a cover and it's packed full of hay. The "Wrap Guard" as the call it is below the drive shaft and you can see the hay stuffed between it and the shaft.
Old 10-18-2016, 05:16 PM
Sorry, I missed seeing the cover in your pics.
Old 10-18-2016, 05:19 PM
Yep this is one of those get the designer of this thing to fix it and see how it is in the real world.
Old 10-18-2016, 05:21 PM
The cover should seal up the spinning shaft. Is it maybe missing a part? Making a shield may help.
My suggestion: don't make the window so big. Rake less into it.
Old 10-18-2016, 05:54 PM
This is a pic from the JD parts. Big space between the 2 shields and they don't seal up to the shaft. I agree about keeping the windrow down.
Old 10-18-2016, 06:02 PM
I guess it's not big enough to have the fully encased shaft.
Smaller windrow or make added protection is the best bet.
Old 10-18-2016, 06:23 PM
Looks like the best answer. Will discuss with the owner.
Old 10-18-2016, 06:52 PM
Dirty Steve's Avatar
Straddling the windrow is the worst for that. Big square bale and round bale machines can be a pain. We had offset small square balers but in big windrows of rye straw the draw bar would drag stuff. I still like your belt idea to protect the drive shaft.
Old 10-18-2016, 07:44 PM
They'd have to figure out how to steal it from CNH first.
Old 10-18-2016, 07:49 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Another possible is to try those plastic driveshaft covers ( designed to protect people) for the exposed rear PTO shafts. Though, the conveyer belt does look like a good solution.
Plow blade
#2 Cart
QA36 snowthower
